Re: 50 hp rude tachometer pole settings question..
You need to find out if the tach is for a 2 stroke outboard with electronic ignition and an alternator output for the tach. Some tachs are for points ignition, some are for inbard engines, etc, etc.<br /><br />If it is meant for CD ignition, and it only has settings for 1,2,3 or 4 cylinders, set it as for a 3 cylinder 2 stroke engine. I had a Smiths tach fitted that had the same system, and the 3 cylinder 2 stroke was the setting that it advised. My engine is a 2 cylinder 55.<br /><br />I was never convinced that it read right though, even though it was new, so I've replaced it with the Faria tach that has proper pole settings.<br /><br />Good luck<br />Steve
