sangerwaker
- Joined
- Jul 29, 2004
- 2,059
They mean as a coolant in a closed system, like a car. You are fine.
http://www.atsdr.cdc.gov/tfacts96.html<br />What are ethylene glycol and propylene glycol? <br />Both ethylene glycol and propylene glycol are clear, colorless, slightly syrupy liquids at room temperature. Either compound may exist in air in the vapor form, although propylene glycol must be heated or briskly shaken to produce a vapor. Ethylene glycol is odorless but has a sweet taste. Propylene glycol is practically odorless and .<br /><br />Both compounds are used to make antifreeze and de-icing solutions for cars, airplanes, and boats; to make polyester compounds; and as solvents in the paint and plastics industries. Ethylene glycol is also an ingredient in photographic developing solutions, hydraulic brake fluids and in inks used in stamp pads, ballpoint pens, and print shops.<br /><br /> The Food and Drug Administration (FDA) has classified propylene glycol as an additive that is "generally recognized as safe" for use in food. It is used to absorb extra water and maintain moisture in certain medicines, cosmetics, or food products. It is a solvent for food colors and flavors. <br /><br />Propylene glycol is also used to create artificial smoke or fog used in fire-fighting training and in theatrical productions.<br /> <br /><br />How can ethylene glycol and propylene glycol affect my health? <br />Eating or drinking very large amounts of ethylene glycol can result in death, while large amounts can result in nausea, convulsions, slurred speech, disorientation, and heart and kidney problems.<br /><br />Female animals that ate large amounts of ethylene glycol had babies with birth defects, while male animals had reduced sperm counts. However, these effects were seen at very high levels and would not be expected in people exposed to lower levels at hazardous waste sites.<br /><br />Ethylene glycol affects the body's chemistry by increasing the amount of acid, resulting in metabolic problems. Similar to ethylene glycol, propylene glycol increases the amount of acid in the body. However, larger amounts of propylene glycol are needed to cause this effect.<br />
