Hi everyone,
Everything started when I accidentally touched my bravo 3 outdrive while I was also touching the floor, and I instantly felt a little shock and decided to try to measure how many volts I was dealing with. This happened when my boat was plugged at the marina receptacle @ 110v AC 60hz.
I've got a reading of 45-50V AC @ 60hz, I measured the voltage with a digital multimeter by placing the black probe on the floor and the another one on a screw. I tried to measure DC current and got about 0v
My boat isn't equipped with earth/grounding(the green wire), just live and neutral AC wiring. I've checked the wiring and everything seems to be fine, I've measured other boats at the marina and most of them share this behavior, is this normal? BTW I use a xantrex truecharge 2 charger.
All the best,
Luiz
All the best,
Luiz
