Re: 50hp Evinrude what year?
Its a 1972 model.<br /><br />50:1 is the ratio for premix.<br /><br />the water doesn't come out a pee hole, it flows from either side outlets on top and to the rear of the cav plate..<br />if you can touch the heads for 5 seconds without burning fingers, its not running hot.<br /><br />do a search for temp gauge on the board if you want to know about fitting an after market temp guage.. <br /><br />also test your overheat horn. touch the tan wire running to the head to earth with the ignition on, and you should hear a horn in your control box sound, thats your overheat alarm.<br /><br />hope that helps.<br /><br />regards<br /><br />Frank
