1975 50hp johnson outboad with johnson control box 50esl75b with original single handle control box with throttle warm up handle / lift lever on side of control box. Because of hard shifting caused by broken gear tooth, I just Installed new shift lever remote control ,which has three gear teeth that line up with the two gear teeth on the shift and throttle plate. ( shift and throttle plate attaches to the outer shift lever/handle used to shift boat motor into forward or reverse).
PROBLEM: After lining up gears of both shift lever remote control with the shift and throttle plate (in the neutral position,and lining up the middle and largest of three gear teeth of shift lever remote control in between the two gear teeth on the shift and throttle plate) I can then shift into forward and reverse, but if i go past the point where the motor engages into forward or reverse and accelerate full throttle to increase engine speed (with outside shift lever horizontal in forward or horizontal in reverse) the shift lever locks and wont allow lever to shift back to neutral. With control box open , I can see while trying to shift back to neutral, the shift lever remote control does not engage with the shift and throttle plate gears correctly and actually tries to move farther in the opposite / wrong direction as it tries to engage with the throttle plate assembly gears. I am doing this with the throttle warm up handle and shift side of control box removed so i can observe. I am lining the gears up each time at the neutral position, where the neutral start switch is depressed and the gears are all engaged in the middle gear slots.
Question: Is this a gear engagement problem, where I need to buy a new shift and throttle plate to match with / mesh with the new shift lever remote control or does the forward and reverse cable attached to the shift lever remote control need to be tightened or adjusted so the shift lever remote control doesnt go too far beyond/away from the shift and throttle plate gears when shifted into full forward or reverse. I can shift the motor into forward and reverse normally back and forward, back and forward as many times as i like as long as i dont go past the gear engagement position , and dont shift further as if to accelerate. Or is it something else. thanks in advance.
