Now that my nice 50 horse is out of commission for a while I'm digging through the pile of semi-functional outboards beside my shop and found a late 1970s or early 1980s 50 hp merc that has 122 psi on every cylinder and starts on the 1st or second pull, I'm not sure why I never sold it actually... But anyway I flashed it up and found that it won't pee, I took apart the water pump and all looks good. When I blow compressed air thru the pee hole it seems to all come out the upper exhaust hole or somewhere near there. Is there a broken valve/ plugged pipe that would cause this. It doesn't even drip out the tell tale, its dry, so my thought is that theres a clogged pipe and the air is finding its way out another way, does this make sense? any other ideas?<br />Thanks,<br />Eric
