50hp Mercury 2stroke issues
Bcole1717
New fuel and plugs. Any suggestions? Runs fine WOT
  • IMG_1052.MOV
  • IMG_1045.MOV
Bcole1717
Explain what your motor is doing / not doing.----Serial is ?
I posted videos to show. One at idle and one revving in neutral. Coughs and shakes intermittently at idle, stalls in and out of gear only at idle. Runs flawless above roughly 2k to WOT. S/N 1B003807
Might not be running on all cylinders.---Start with compression test and spark test.
Bcole1717
Wouldn’t that effect the engine at all rpms? I also took air box off and felt inlet of carbs and all seem to have vacuum so I don’t think it’s the reed valves. I did notice how wet and saturated the inlets were with gas. Also the air box was heavily coated in gas/grime
jimmbo
Start with a Compression and Spark Test. Spark has to be able to jump a 7/16" gap
