I have a fifty HP. Model... 507L8B. Serial 1048 this is all I can read. not sure if its all there or not.
This unit starts fine with choke assist. how ever it spits back like a lean runner.
I feel that the carb is the culprit I have not cleaned it yet and the whole rig has set for several months. started first time today in about six months. and even then it was not run, as it died when put in gear,but would idle if not engaged in forward or reverse.
Now I have it and will go through the carburetor, not sure if it needs a kit as it starts and runs fine but I don't like the spitting back , Could this be a gasket or perhaps a vacuum leak ? I have not found any thing that could cause this by inspection. course I know this does not cut any thing when there is a bug that gives you fits.
Are there any tips to be aware of when taking the carb apart??? It looks simple and I will probably do this small job
my self. I do not have a book but its just a small carb. what can go wrong? Thanks guys for any help. Paul.
