50HP tiller steer bearings
noelm
HI
I posted about this Engine some time ago, a friend of mine has a tiller steer 50 "mix your own oil" and the main Bearing on the centre cylinder failed, the crank was rebuilt (by a Motor bike shop) all new bearings including big ends, cylinders where checked and found to be good and the Engine was rebuilt by a Yamaha dealer, all went well for about 2 months, the Motor started making ugly noises again, it was stripped down yesterday, and the same Bearing has gone again, as well as the centre big end, all cyclinders are very slightly scored/scuffed as well, when the rebuild was done, the Water Pump was done, carbies done, block cleaned, the whole lot (so they say) now my question is, could there be a problem (unfound) with the Motor before, was the rebuild a dud or is there a common problem with the Crank Bearings in these Motors? at the moment, there is a bit of tension between the Dealer and the Owner as to who will pay for the reapirs.
noelm
Re: 50HP tiller steer bearings
I can only assume that it was all OK, as it was done by a Shop that does Cranks all the time, although it is a Motor Bike shop.
bradj84
Just standing back and looking at the situation, it seems like balance might be an issue. When you pull it apart might be worth taking it to another machine shop to get the crank looked at. Just my two cents though, I'm far (really far) from mechanic status.
bradj84
noelm
Yeah maybe, perhaps the Gurus on all things Yamaha (rodbolt and Ray) may have some sort of comment on the situation.
rodbolt
bearing failures are rather rare, carefully inspect the block for any missing check valves, some had them some did not and Non US market motors we dont get to see much.
deejaycee_2000
what fuel to oil ratio do you mix the fuel? was this a thundercat race motor?
