50HP won't go into reverse in water only, out it works fine
Malone111
92 Yamaha 50 goes into reverse fine out of water, but will not it water unless you really really work it into gear.
rodbolt
Re: 50HP won't go into reverse in water only, out it works fine
carefully inspect the shift shaft, pre 95 motors tended to corrode in two.
