50ph mercury banging
scotssandy
my 50hp mercury bangs and judders alot when put in forward gear this goes on for about a minute then it settles down, it goes into and runs in reverse np, could this be just needing adjusting or is it the gear box on the way out ????
Nos4r2
Re: 50ph mercury banging
like grinding the gears type banging?
scotssandy
no it does not sound like gears ,just a heave thumping as if there was something in the prop ?
Nos4r2
Have you checked for play in the pivot it steers on?
scotssandy
there is no play in the pivot part, i hope it is just needing to be adjusted at the gear linkage,
