Texasmark
- Joined
- Dec 20, 2005
- 14,795
Was over in props talking about things and the subject of OMC cubic inch displacement came up concerning the old twins that started out at 25 hp (with the sliding throttle across the front and pressurized fuel tank) up through the twin 35's of roughly the '58-59 era.
Many a time, as a youngster, I'd see one of these engines, even the 25 hp, on the back of a 14-16' wide beam wooden boat with 2-3 fishermen/women full of gear, blast of across the water doing a respectable speed like 20 to 25 mph. Wife's family had a 35 on a 14' wood runabout and it would tug a pair of skiers at a fast enough clip to have fun.
I know they turned a pretty large dia prop (12-13"?) with a pretty shallow pitch (10-12"?), and as I remember the engine rpm max rating was like 4500.
I always thought they did it with a lot more cubes than Merc used at the time for the same hp. What I'm seeing today in the other post is that the cubes weren't all that big and that they turned a high gear ratio lower unit, so all that low end thrust came from the gear reduction per se, not the "big block" syndrome.
The Mercs of the day were 4 cyl Mark 30 or Mark 55 at 30-40 hp and I remember them having higher rpm limits (they screamed while the OMC's were very quiet) and had a smaller, higher pitched prop.
So I guess their gears were more like 2:1 whereas the OMC was 2.4 something:1. One thing was for sure and that was the OMC could pull circles around the Merc, but on a light fast boat the Merc was tops. (Heck, I was just a kid, I didn't know anything about specifications....so I don't have any real numbers of my own.)
Used to have the Old OMC site from a guy in Germany and it had all the specs and brochures and all, but I can't find it anymore.
Thanks,
Mark
Thanks,
Mark
