Anyone know Specs for a 51 gale 5 hp. flywheel torque? points ? and Plugs? thanks Randy
O ooldschooll Petty Officer 2nd Class Joined Nov 23, 2008 Messages 124 Jan 22, 2009 #1 Anyone know Specs for a 51 gale 5 hp. flywheel torque? points ? and Plugs? thanks Randy
O ooldschooll Petty Officer 2nd Class Joined Nov 23, 2008 Messages 124 Jan 22, 2009 #2 Re: 51 gale specs? Sorry51 gale 5 hp
JB Honorary Moderator Emeritus Joined Mar 25, 2001 Messages 45,907 Jan 22, 2009 #3 Re: 51 gale specs? The small JohnnyRudes of that era use Champion J6C plugs gapped at .030" and points set at .020". I suspect the Gale was in the family.
S steelespike Supreme Mariner Joined Apr 26, 2002 Messages 19,069 Jan 22, 2009 #4 Re: 51 gale specs? Flywheel nut torque 480-540 inch pounds.Other specs as suggested.
O ohm116 Petty Officer 1st Class Joined Dec 10, 2008 Messages 203 Jan 22, 2009 #5 Re: 51 gale specs? That's what I did with my 5D10, check post lower down.
O ooldschooll Petty Officer 2nd Class Joined Nov 23, 2008 Messages 124 Jan 22, 2009 #6 Re: 51 gale specs? Thanks I read a post that called for .018 on the points and was thinking with all the parts the same as my 5.5 hp the settings should be also. I've got it almost done and will have pics soon.
