52911d sea king monkey wards..timing how to set
boater121
is it the same as jonhson evinrude? points set when point trigger is lined up with key way? on either side of course i know its .20
1946Zephyr
Re: 52911d sea king monkey wards..timing how to set
Yep. It all sets the same. Turn the cam to the highest point and set it. Some of those will have a "TOP" spot on the cam and that is the area you have the heel of the points.
boater121
figured it would be thanks pick dup motor for 50 .00 and just needs recoil spring..the little brass retainer popped off...im just ordering new spring assembly
