Re: 53 evinrude fuel pump conversion
Fuel pressure is determined by the pressures in the crankcase--roughly 4psi. So the fuel pressure will be around 4psi, same as what goes into the pressure tank. Fuel GPH is determined by other factors, but 14 liters is way more than the motor will consume. The float valve just shuts off the flow when it gets enough, so no problem.
