I've been working on this motor for a while, and now, i hope its my final issue to solve.
I can't get it to keep running. I've rebuilt the mag plate and it has hot spark. I can get it to fire up, if i choke it first, and then pull then unchocke then pull again, it fires up briefly, and the dies. I've taken the carb apart, and it is clean. gas goes into carb no problem, it even pukes out little out the front if i choke and pull too many times.
fuel pump #304089, i tried taking it apart to see if its busted, but i could only get first layer off, it appears no easily available videos on those either. i'm almost 100% that this pump was aftermarket, as my 56 johnson has a dual fuel tank line, and this motor appears to have air line plugged up, and then they converted this motor into a single fuel line motor by adding that fuel pump
below are 2 pics, one is showing where that fuel pump was mounted on the block, and the other is showing that air line on the right of the fuel line fuel line has yellow zip tie, that air line is capped off.
I'm new at motors, so if more info is needed, i'd be glad to add it
