had 30 psi on both pistons, put motor horizontally poured about 2oz in each cylinder let set for over 8 hrs.sanded head on flat glass until shiny smooth, put new head gasket on , checked pressure again and still 30/30 hooked gas back up pulled and pulled no start,pulled plugs shot air in and put unoiled gasoline in both cylinders and it fired right up and ran for about 4 or 5 mins.and then died [see prev posts] checked again still at 30 psi on both,so pulled plate off side and see some scoring but not anything deep,dont see any carbon on the rings,cylinder walls looks good ,nothing deep, so how would i know whats bad?will also sand head again,or should i take it to a shop and have them plane it,this is my first time doing this so i dont know thanks for the advice.
