73 engine #555FH
I am having trouble understanding the way my engine is currently wired (ignition) this engine has two coils under the flywheel and no charging system (alternator) I beleive it is Mag style the coils have magnetes around them.
OK this is my confusion, the blue ignition wires are currently coming from the engine terminal block to the screw on the POINTS the condenser wire also is connected to the same screw and one of the wires from the coil is also connected their (dont know if its the coil + or -) the condenser is mounted on one of the coil screws.
Now every schamatic I have found shows the blue wires going directly to the + coil and ending their then then you have a brown wire which terminates at one set of points and a white wire comming from the other and terminating at the terminal block.
I am having a shaking and missing problem at idle but top end runs good so I am wondering if my engine is wired wrong even though it runs.
Also I changed the ignition switch and now with the blue wire connected to (I) when I turn on the key the circuit braker pops.
My manual has poor pictures and I need to see how the actual set up undeer the flywheel is supposed to be.
Any help from you guys will be greatly accepted.
