55# Evinrude Trolling Motor
Safebet
I have a 55#, 12/24 volt trolling motor, hand control, with a 2 blade plastic prop that I need to replace. It is 3-speed forward, pull the hand out and it's 3 speed backwards.
My boat is a 1985 18' Ebbtide DynaTrak 179. The tolling motor works great.
I can find no numbers on the trolling motor. The prop mounts to the motor with a cotter key. You slip the blade onto the shaft onto a thru shaft pin and then you run a cotter key thru the hub. to lock it into place.
The place where you run the cotter key through is tapered to about 5/8 to 3/4". Can anyone help me with identification. I can take a pic if necessary. I really like this motor, it is very strong and pulls my 18' just great.
Safebet
Re: 55# Evinrude Trolling Motor
Thank you, very much. Through your information I have found the model # and part #'s I need. Now to find where to order them.
Thanks, again.
Safebet
After further research of the link you gave me, I found where to order.
Thanks, again.
