55 horse 1979 evinrude won't go into reverse
asthedeer
Hello everbody
My 55 horse 1979 evinrude won't go into reverse. When shifted into reverse the gears grind badly and it won't engage the prop into reverse.
Please let me know what you think
Thank you kindly
Colin
tx1961whaler
Re: 55 horse 1979 evinrude won't go into reverse
If it shifts OK manually with the shift cable disconnected, then the cable needs adjusting.
If shifting manually doesn't work, then it may be that the shift rod height is not correct
boobie
Either your shift linkage adjustment is not adjusted correctly or the shift dog and reverse gear are worn badly.
boobie
tx1961, how could the shift rod height change??
Daviet
Have you checked the lower unit oil, any metal particles?
tx1961whaler
It's threaded into the gearcase. It sometimes gets messed up after changing the water pump impeller.
