CobisCaller
- Joined
- Jul 22, 2009
- 32
Hello
This motor is a 1977, 55hp Johnson. Model 55EL77D
I have an intermittent no spark problem that reappeared yesterday.
Put the boat in and it wouldn't fire. Got out my spark plug light and verified no spark. Took off the power pack cover, left it off, and removed the Black/Yellow wire. Turned it over and it fired up. I shut off the key and pushed the wire back against the terminal and it died. I then put the power pack cover back on and left the wire hanging in the air and turned the key on and tried to start it. Again no spark. I then removed the power pack cover and turned it over. It started right up. I again turmed the key off and pressed the wire against the terminal to kill it.
I hooked the black/yellow wire back up, left the power pack cover off and turned it on. It started immediately several times and ran fine the rest of the day.
Sooooo, it seems that the terminals inside are shorting out through the gasket to the cover?
Should I just replace the gasket and insulator piece or is there a possibility that something is bad within the pack itself. The gasket is kinda cracked in a couple places. Just seeing what you guys thought before I order anything.
Thanks in advance!
Thanks in advance!
