550 mca battery for my V6 200HP MERC:mad:
BIGKASH
Yea, that looks to be my problem with slow starter speed even when fully charged and load test shows ok...I was being cheap and bought the west marine 550 MCA marine battery...while searching this site It looks like i need at least 1000 CCA battery do you guys agree ?<br /><br />thanks
Kenny Bush
Re: 550 mca battery for my V6 200HP MERC:mad:
I use a 750 cca Interstate "MegaTron" on each of my 200's. They are also paralleled with a Perko Battery switch. I have had no problems with starting power. I think you would need at least 750 cca's. Goodluck.....BushCat
JB
Ahoy, Bigkash.<br /><br />Before you blame your troubles on the battery, you need to confirm that the starter is getting enough voltage.<br /><br />With a DC voltmeter:<br /><br />Measure battery voltage when starter is engaged. It should not fall below about 9 volts. If it does, your battery is bad or too small.<br /><br />Measure voltage at starter (big lug to block) It should not be more than 1 volt below battery voltage when engaged.<br /><br />If the voltage getting to the starter is too low, your problem is in the wiring of the high current circuit, not the battery.<br /><br />Measure the voltage across EACH connection, including battery post to cable and solenoid. Each should measure less than .3 volts with starter engaged. If there is too much voltage, redo that connection.<br /><br />Good luck. :)
roscoe
MCA, CCA, and CA, are different ways to measure battery amperage, measuring under different environmental conditions. Kind of comparing apples to rapalas. <br /><br />I would think you could try a battery from your tow vehicle and have you battery question answered real quick.<br /><br />Good Luck.
