i have just received on trade this boat & motor and it will pull start on the 2nd or 3rd pull seems to run ok except the only way I can get it to stop is to choke it to death. The wiring, what little there is, is a mess. Splices and unterminated ends everywhere. The manual is calling for a 6 volt battery but the previous owner has a now dead 12volt hooked up to it. Another difference from the manual, it is using a single line tank an fuel line. The model # for the motor is 25924. The manual that came with it is a evinrude service manual which for some reason does not include any good wiring diagrams. Did I mention the engine will pull start no matter what the ingition swith is set at. probably not even connected to the motor. The boat is also a 56. It is a 14 foot starcraft fiberglass runabout. No apparent rot or soft fiberglass. I was told this is the original boat & motor combonation. What have I gotten into? Does anyone have a wiring diagram for this motor and / or Boat. The starter solinoid and most of the wire nest is on a electrical junction box under the transom well.
