bspeth
- Joined
- Aug 30, 2013
- 758
Ok so I repaired the water pump and pressurized the gear case and found that I had two leaks before. I thought I had found my only problem in the driveshaft seal in the water pump base but the upper gear housing shift rod bushing and oring are leaking also. Does anyone know the procedure for replacement? I am assuming I need to drop the lower gear case,but can the shift rod be removed on its own or do I need to disassemble the entire gear case?Thanks-B
