Hi. I'm having trouble with my '56 35HP Johnson Javelin. A little background info: It sat untouched for 6 years and when we got it running again it had several great hours on the water, maybe idled a little rough but would go to full power just fine. One day, it just wouldn't get to full power. After cruising along for 10 mins or so it finally opened up and ran fine for about 15 mins. We cut the engine for a little while and upon restarting, it had the same problem where it wouldn't get to full power. I'd say it was about 1/4 power. I thought it was a fuel mix problem so I took off the high speed fuel mix lever and turned it back and forth - now I've lost my spot. (could this be the problem?)
When we got it back home, we found out that one of the cylinders was not firing so the coils were replaced (with the help of the iboats experts - thanks!) and it sounded like it was running fine. Got it back on the river this evening and it is idling better and running a little faster at WOT, but it's still not quite up to speed. Maybe around 1/2 to 3/4 power. Any ideas?
Also - I just read that putting carb cleaner in a 2-stroke is a bad idea. It's been through around 3 gallons of gas with the cleaner - oops?
Thanks in advance for your help.
