'56 Johnson low/high speed needle valves
brooksk
My '56 Johnson 5.5hp has both speed valves (low and high) deformed at the cone due to overtightening. I'd like to replace if possible but havent't found a supplier who has these, only things I find carb related are seats and needles and the packing rings. Are there replacements available?
rolmops
Re: '56 Johnson low/high speed needle valves
Hello.<br />If I understand you right,the deformed "speed valves", are in fact the adjustable needle valves that sit in the carburator housing.<br />If this is what you are looking for,go to:<br />www.tcoutboard.com<br />They specialize in that sort of stuff.<br />Good luck.
