89Aluma
- Joined
- Aug 23, 2016
- 89
Hi all just when I get this frankenrude running well it seems to give me more trouble, 57 evinrude 35 power head on a 56 30 hp leg and hood we cruising on the river around half throttle maybe a little less and it runs great but every once in a while it acts like it's hitting something the motor stutters makes a klack noise once and goes back to running fine I thought it had a 30 hp carb on it so I put one off of another 35 of the same year on it. I've messed with the link and synch thinking it wasn't opening the carb up enough compared to the timing advance basically making a lean sneeze I cleaned the carb thoughouly! Retired the points again with a multimeter replaced the coils and wires compression is still 120 both cylinders took it back out and really messes with the needles! Got it running god at idle still does the kick back sneeze thing around half throttle but now won't get up to full throttle like it should I played with the high speed while hauling down river leaned it out and it got better but after running for 40 seconds or so at higher rpm it would surge the rpm would suddenly drop and start picking back up it even died one time while this happened took a few cranks to get going again then I unplugged the fuel line and ran the fuel out at the dock and the way it runs when running out of fuel reminded me of how it kicks at half throttle could I be looking at a fuel pump issue? Sorry for the run on sentence lol
