Shakedownscott
- Joined
- Jul 12, 2011
- 179
This motor followed me home a while back. I have been using it as a parts motor for other projects, as it was incomplete when I got it.
I have been slowly collecting parts for her with the thought of some day getting her back together. One puzzle I have is the water tube. When I removed the lower unit the water tube pulled out from the top of the exhaust housing. I don't think it was really hooked up to anything, it came out with no resistance.
Here is a picture of the water tube and water pump housing.
Here is the end of the tube that goes into the exhaust housing.
When I look down at where the tube should go, it looks like there is a copper tube in there and a brass fitting all swedged in.
Here is a photo of the water tube held next to the exhaust housing. The tube has pretty much the same diameter as the brass fitting.
I have tried to tap out the brass fitting from the bottom and also tried to rotate it. Other than drilling it out, I am not sure what else to do. Has anyone had these apart before? Any advise would be appreciated.
