Medicman613
- Joined
- Mar 16, 2015
- 19
Hey all, i rebuilt a 1957 johnson seahorse 7.5hp motor and installed a new impellor, new points and condensors, and also new gasket around the carb. (Carb was cleaned but was extremely clean to begin with. Motor starts one pull and idles perfectly. The problem i have is that when you give it full throttle it is very delayed to build up speed and once it gets to top speed it will run there for a minute and then drop off a few km/h. The carb is adjusted as per the original manual and the fuel is mixed as per the original manual. Any thoughts as to what i can try next?
Thanks,
Curtis
Thanks,
Curtis
