58 35 hp johnson thermostat?
PJHawkins
I've just replaced my impeller. Now for some reason I am not pumping water at all. I have pulled the lower unit a half dozen times already to no avail. I have been reading alot about a thermostat but have seen nothing that even resembles such a thing on my unit, (Super sea-horse). Should I be pulling the soft plug above the exhaust?
CATransplant
Re: 58 35 hp johnson thermostat?
If your engine doesn't have the cream-colored and gold hood, it doesn't have a thermostat. Only the Super Seahorses of that year incorporate a thermostat. On those models, the thermostat is under a cover with three screws on top of the engine.<br /><br />Did you make sure the key that drives the impeller was in place when you installed the impeller? If not, then the impeller won't turn.
PJHawkins
Yes the motor is a super sea-horse. The pump works fine when I take off the lower unit and turn the shaft in water but for some reason it does not get to the block. I've checked for blockage and all is clear.
nimmor
I have a 1959 35 super seahorse which should be pretty much like yours. The thermostat is inside a little semi domed housing with three screws on the back of the engine at the top of the head.
PJHawkins
I have determined I have no thermostat. But for the life of me I cannot figure out why that darn thing will not pump water to the power head. I have tried everything, (Except for the cure). I have talked with mech. at the local marina and he too is at a loss.
Paul Moir
Are you operating it in water deep enough? The water line should be up above the water pump for it to prime.<br /><br />Oh, one big question! There's two impellers for '58 35hp engines - ones for thermostated ones and ones for those without. What part number impeller did you get??<br /><br />(The thermostat should be really obvious. It should be under the plate at the top of the 'stand pipe' on the starboard side of the head. If none of that makes any sense, you don't have one)<br /><br />EDIT: (Even more obvious, you would have noticed there's two copper water tubes in the thermostated engine and only one in the non-thermostated :) )
krb113
Just went thru this on my 40 hp Ev. Check your compression and see if it is o.k. Mine turned out to be a blown head gasket. Put a new one on and I am now back to pumping water. Nearly drove me to dry land!!
