Hi,
My 1958 35hp RDE-19C is equiped with a key start, pushbutton electric choke, mercury
safety switch and vacuum safety switch. I'm reasonably confident everything is wired correctly according to a
schematic diagram I have. The engine starts, runs, and I can shut it down with either the manual or electric
choke. It will not, however, shut down when I turn the key switch to off. I can disconnect the kill wires coming
off the points and short them to ground to kill the spark. When hooked to the "M" terminals on the key switch,
the engine continues running when the switch is in the off position. With the kill wires disconnected from the key
switch, there is continuity between the two "M" terminals with the key in the off position. If there is continuity
between the "M" terminals with the switch off, why aren't the points shorted in the off position when the kill wires
are hooked up to the switch? The kill wire for the upper cylinder goes directly from the key switch "M" terminal
to the point set for the upper cylinder. The kill wire for the lower cylinder goes to the vacuum safety switch then
to the other "M" terminal on the key switch. I've been struggling with this for over a week. The easy way out would
be to "bag it" and use either the manual or electric choke to kill the engine, but now I'm on a mission and would love
to figure this out and have the engine shut down when the switch is in the off position. Any wizards out there who
can help me???
P.S. I have good ground between the switch box and the powerhead via the harness, and continuity on the kill wires
to the "M" terminals. The vacuum switch is functional - I can short the lower point set by grounding the switch.
Thanks in advance
Antonino
can help me???
Thanks in advance
Antonino
