I have two issues:
I bought a Sierra carb kit. Some of the parts are a bit unclear. In the picture below there are 6 packing washers (I think). Do I put 3 each on the low and high speed needle valves? Should I use the float valve spring? The old one does not have a spring. What about the 'O' rings and the thinner round gasket--it does not seem to have a purpose. I already found the one for the float valve seat.
Second issue. I have been reading about removing the high speed jet with a special tool. In the picture below, I do not see an evidence of a jet that can be removed. Does this model (15024) not have one?
