58 Gale 35 hp prop
happytimes63
Hi
Need help finding a prop for my 58 Gale 35 hp. Pretty sure it is the same one that goes on the 35 hp johnson of the same year. We spun the old one over the weekend, and the marine store here on i boats is out of stock for all the possible combinations I thought might work.
The numbers on the prop are
304825 and 10 3/8 x 13 1/4 3 blade Aluminum pin drive clockwise rotation. Can the old one be rebuilt perhaps.
Thanks for any help.
steelespike
Re: 58 Gale 35 hp prop
Yes a prop shop can probably repair it. If its badly worn ,props can actually become undersized from wear,you might be better off getting something better.Props from the many private label Gale built motors and the Evinrude/ Johnson motors will fit.You might check ebay,and www.aomci.org
webvertise.
