Wildthing1
- Joined
- Oct 13, 2008
- 12
Hi,
I am completely new to outboard motors and am trying to rebuild a 58 Johnson Super Sea Horse for a 1954 Feathercraft. (Currently have rebuild kits for: Electrical system, carburetor, Fuel pump, and impeller on order)
Motor appears to be in very good condition. The motor was on a boat under a shed since the 60's (Dry). I have kept it inside since I bought it 2 years ago. This motor hasn't been run and hasn't seen a lake since the 60's.
I left the motor outside (on the boat) a few weeks ago and it rained (for the first time in 4 months).This weekend I went to drain the lower unit and got 1-2 cups of VERY clear water (No rust, no oil, no discoloration). Interestingly enough, the top plug was holding suction pretty good as a lot more released (with a sucking sound) when I opened that.
Assuming water from the 60's would've evaporated or discolored by now, the only place this water could have come from is the recent rain.
1. Is there a path from the top of the motor that would allow the rain water to run into the lower unit?
2. Based on this information is it critical I rebuild the lower unit with new seals? Is rebuilding it relatively simple?
