Wildthing1
- Joined
- Oct 13, 2008
- 12
Anyone know how to replace the shift seal on a '58 35hp Johnson SuperSeaHorse?
I've read most of the threads on this subject.
Upon inspection of my lower unit:
1. There appears to be a brass? bearing (press fit) from the bottom.
2. There does not appear to be a avenue to press it through the LU casting.
The method proposed by this thread doesn't seem to work in this case (because of the casting not being made for the bearing to pass through):
http://forums.iboats.com/showthread.php?t=277190
I am a little timid to mess with it because I just got through chiseling out the prop shaft bearing in a dozen or so pieces (nerve wracking if you've never done it before).
Anyone know how to remove this bearing/seal?
