Re: 59' 18hp Johnson Prop Seal
Step by Step instructions for replacing prop seal on a 1959 Johnson 18hp outboard.
1. Drain Lower unit of oil then Remove Propeller.
2. Remove Skeg . The skeg is most bottom part of the lower unit. It is attached by 9 screws. There are 8 screws on the bottom and one on the side.
3. Remove bushing. The bushing is located on the prop shaft. It should pull right off the shaft.
4. Remove cap off bushing. I used a small screwdriver to wedge the cap off by gently tapping the screwdriver with a hammer.
5. Remove Seal from inside bushing. After you remove the cap, the Seal is now exposed. To remove the seal you need to push it out. Again, I used a small screwdriver and hammer. I am sure there is a proper tool for this but my method worked just fine. Place the bushing on flat wood surface with seal on the bottom side. Point the screw driver through the top hole of the bushing at an angle. Push it downwards until you reach the plastic?s of the seal. The screwdriver should catch on the inside of the seal. Hit down on the seal. Then do the same thing on the opposite side of the seal. Repeat this until the seal has worked out until flush with the bottom of the bushing. You should have to use some pretty good force to get it moving. I then placed the bushing in a wood vice to knock the seal the rest of the way out.
6. Insert Seal into bushing. I used a spark plug socket and a hammer to press the seal into the bushing. I placed the bushing on a wood surface with side where the seal goes up. I put the seal into place on top of the bushing and pressed down with my hands and wedged the seal into place at a level position. I then took the spark plug socket and placed it on top of the seal. I gently hit the top of the socket to press the seal into the bushing. Once the seal is seated all the way into the bushing the hard part is done.
7. If you bought the seal package
http://www.iboats.com/mall/partfind...gd_poid=110559&gd_row=13&**********=226867751 You should replace the bushing seal as well. The bushing seal is on the outside of the bushing.
8. Put the bushing back on the prop shaft with seal side closest to the propeller. There is a hole in the bushing that should line up with a pole protruding from the Lower Unit casing.
9. Put some gasket sealer on the skeg where the spaghetti gasket goes. Cut the spaghetti gasket to fit in the groove of the sgeg.
10. Line up the yoke screw correctly with the skeg almost in place. Once you have the yoke screw lined up put the skeg back into place. You will probably have to jostle it around a little to get back.
11. Put all the remaining screws back in.
Here are some pictures of the bushing just after removing the cap.
http://pissantfarmers.net/aboat2.jpg
http://pissantfarmers.net/aboat3.jpg
