This weekend I had the boat out for a run, We stopped at a friends place, but when I pulled up to his dock i tried to put the motor in Neutral but it stayed in forward. My boat ran right through his dock... Quite embarrasing.. anyway when i got the boat back on the trailer I noticed that the Screw on the lower unit was missing. This would be the screw that you are not supposed to touch, the one by the drain plug. I tore the lower unit apart yesterday and replaced the screw but now it leaks oil.. Is there an O ring or nylon seal that is supposed to go here?? also can I use Loctight on this screw to prevent it from coming loose again?? If I can use locktight What kind should I use?? Thanks in advance. Timbit
