Poorboywaterfowl
- Joined
- Aug 12, 2014
- 30
59 Evinrude fastwin- back story I received this motor as a gift basically. The recoil starter was locked up, after fixing it and pulling the flywheel and replacing ignition(coils, points, condensors) and going through the carb completely twice, new plugs, and a decarb I have a terrible sneeze at idle that will kill the motor. Link and sync seems fine, timing checked multiple times I just can't seem to point it out. I did notice today that the fuel pump has a fine mist coming out of what appears to be a weep hole. Fuel pump was on a motor that ran before(omc part #385784) and worked perfect. I'm just wondering if this will fix my sneeze, or if I need to dig deeper and order more parts when i order the rebuild kit for the fuel pump. Motor runs great from just above the start position to full throttle. I also noticed the top plug was black and dry while the bottom still looked like new and was slightly wet. I have a very nice blue snap of spark on my open air tester as well. Motor also is hard to start, almost has to be choked to start when it sits for more than 5 minutes. This all started after its first voyage, where it ran perfectly fine until I went to load the boat back on the trailer and I had a choke decent break(that's also been replaced) one other thing, i pulled the lower unit off last week to double check the impeller, and I had a very light blue oily substance in the transom clamp section. Almost like 2 stroke oil/water mix. Thanks in advance
