59 evinrude power problem
CGE
I have a 59 evinrude 18hp Fastwin -- it idles fine and will rev in neutral. In gear it very little power and speed at WOT - used to be much faster -- any suggestions ??
rolmops
Re: 59 evinrude power problem
Hello.<br />Try replacing your spark plugs and dump a can of seafoam in your fuel and run it.Check to see if your contacts are still in good shape and at o.020 inch.<br />If none of the above works you may have to take your carb apart and clean it.<br />Good luck.
alcan
I don't know, sounds like it is only running on one cylender? Check compression and spark. Get back to us with a few more details.
JB
While Rolmops suggestions might fix it, I am with Alcan on this.<br /><br />Find out what is wrong first. Then fix it.<br /><br />Good luck. :)
CGE
Thanks to all -- I will check it out and let you know the findings
