'59 Flying Scott Water ump
negrunke
I have a '59 Flying Scott 60 HP that I have just gotten running. However it is over heating. I can't tell if the impeller is pumping water. Where is the water discharged at? The only place I see water discharging is from a small weep hole on the left site right under the engine. If it needs a new impeller/water pump, anyone know where I could find one? Been looking every where with no success.
flyingscott
You will need to have one made. Join the AOMCI members there make them you will need your old hub. Water comes out the peephole on the left side of the motor and out the exhaust relief should.be the bulk of it.
negrunke
Is the exhaust relief the round port at the back above the water line? Did not see water coming out of there.
