59 gale 35hp, cam follower not opening throttle enough to start
35hpdan
Hello
Fixing 35 gale, it seems after putting new ignition in, the cam follower does not open throttle enough to start motor, if I stick a feather on part of linkage that is attached to recoil cover, it pushes down enough to open throttle to start, any help would be great, also any pics so I can what you mean
Thanks dan
35hpdan
Re: 59 gale 35hp, cam follower not opening throttle enough to start
Hi
I'm thinking when I pulled the ignition hub off, I may have positioned the cam wheel in the wrong holes, will pull ignition hub that houses all ignition off and re position it, did this when replaced ignition wiresn what do you think?
Thanks dan
35hpdan
Hi all
Took ignition hub off, non adjustable, but when I put it back, motor ran then died, guess carb need adjusting
