hello
i have a 1959 gale 35hp , i changed all the ignition, i checked the plugs, one is almost dry(top), the other is fouled(bottom), do i adjust the carb hi/low settings to fix that? or a carb rebuild? i pull the top plug wire and it runs the same, if i plug in top wire and unplug bottom(plug which looks fouled), makes the motor not start/run any help would be great
thanks
dan
thanks
dan
