asdasc
- Joined
- Aug 28, 2008
- 680
Hi Folks, I have an odd problem that I can't figure out. I was having issues with my 18hp slipping out of gear in forward. I thought it might be due to the connection on the shift shaft behind the oval plate in the leg, but that was fine. Then I noticed that I can adjust the shifter at the top. There is a couple screws holding the shift lever in place and when you loosen them, I can rotate that lever. I have adjusted it and now it won't 'lock' into either forward or reverse.
How do you adjust that?
Thanks,
Steve
Thanks,
Steve
