Re: 59 Johnson 35hp what to set the compresion release
if you cannot find the correct gap for the compresion release, then set the rocker just against the valve it should NOT have presure against it enuf (enough) to hold the valve open even when hot! It should open when rope started, maybe some one has the setting or can give you more details for setting it, that is how I set the release valves on my dirt bikes! You do not want them to leak when running.<br />Richard
