I recently got involved in restoring an old 15'cobia.it has a '59 50 hp v4 on it.it runs like a scalded dog out of the water-hooked up to water of course.when it gets to the lake it just doesnt want to go.i thought that a 50 hp would've made this boat fly.it has a michigan brass?? prop.i have no idea what the pitch or anything else for that matter.the only numbers i can find on the prop is 104.it says cut and cutter.is this the correct prop for this setup?or is this the decarb solution.i have cleaned the carbs(2).i have no idea where the high speed jets are so i dont know if they need to be cleaned.and last but definitely not least only 50 psi at all 4 cylinders.plz help!
