5HP Merc quits after idle using internal tank
Dugbug
:confused:5HP Merc, 2 Stroke, rebuilt in 2006. Using external (tank) runs fine, but when using internal it dies within a minute at anything above idle speed. Same gas (new) in both external and internal. Drained internal tank, no obstructions noted... doesnt make sense that it would be filter as external uses same... also gas is coming out of the fuel line okay. Does anybody have a suggestion? - Doug
TOHATSU GURU
Re: 5HP Merc quits after idle using internal tank
You probably have a blockage at the fuel ****.
