kenny nunez
- Joined
- Jun 20, 2017
- 3,477
I recently purchased a 18' Donzi 6.2 MPI that will not go over 3k RPM. The sea water pump impeller is new, the fuel injectors have been flow tested, the 93 gas is ethanol free and the tank was drained. The Cool fuel pump was removed and the screen was inspected and was clean. The fuel filters are new.
The boat jumps up to plane @ 2k rpm, and runs perfect up to 2800- 3000 then just noses over until the throttle is pulled back slightly to the 2500 range.
The Rinda scanner shows no codes. With a fuel pressure gauge attached to the rail the pressure is 40@ idle and 43 with the vacuum line removed. When the the engine is between 2500 - 3000 the fuel pressure gauge needle constantly bounces from 30-50 . I am really scratching my head at this point. Any suggestions?
