Motor has been running great. Motor about 1 year old. I am the first user, have maintained meticulously with manufactures break in etc. This past weekend, well into the day, with the engine warmed up completely, the boat engine died at 1/2 throttle. Right before it died, the rpm started jumping all over. Temp was normal, oil pressure was normal. Waited a couple of seconds, raised prop to check for plugged inlet/prop/etc. Everything fine. Started and got about 50 yards and same thing. After docking I took off the flame arrester cover and found a red reset switch - on top of block, just behind the flame arrestor - assumption is that it is the EFI module reset - owners maual did not give description. Pushed the reset switch and boat started on first try and ran great rest of day. The next morning, ran for about 1 hour great then stalled out. I pushed the reset button,boat started and ran great as I headed back for the dock (about 4 miles) ran at 1/4, 1/2, full throttle varying speeds - ran fine. Just just as I was pulling into the dock it started stalling again. Is it fair to assume that this is an EFI module problem? Any suggestions on what to look for when I call the dealer? Any help would be appreciated.
