Hi all. Great forum. I have a 1971 6 hp Evinrude twin cyl. It has been a great motor. Started 3rd pull after 3 years in storage. Here's the problem. It idles fine at very, very low rpm. It runs great at full throttle. But in between is where the problem is. As the throttle is in creased it bogs a bit the jumps to higher rpm. Its harder to do in a barrel but in the lake where there's no cavitation and it's under a constant load, when I increase the throttle it will not go full it just runs kind of boggy then wham!, all of a sudden it cuts irratically into high rpm. ??? Points,fuel,?? Totally baffled here. Any thoughts would be appreciated. Thanks
