Re: 6 hp johnson with no info plate
the 66 model looks close. i can't tell what color the outside of the motor is. someone painted it a nice metallic blue.thats probably why the plate is gone.the block and surrounding area inside is medium gray. the hood is white. there are three decals on the side,one is the seahorse logo, then the johnson name and then a burgee with a 6 in it.this is where i assumed it was a 6hp.it has a three bladed prop.f.n.r. shifting. throttle on the steering arm.it has the lean-rich knob on the front,which i have no idea how many turns out it should have been when i reassembled the carb.(forgot to count when i backed it out...sigh). not sure how to use it when the motor is running.the motor also has a 4 position trim.wow i hope this helps.the little guy runs sweet when the needle is unstuck.......sid
